-   Mitsubishi Outlander (https://mitsubishiforum.com/forum/mitsubishi-outlander-10/)
-   -   Jacking points / Jack Stands (https://mitsubishiforum.com/forum/mitsubishi-outlander-10/jacking-points-jack-stands-27347/)
n0c7 May 5, 2008 01:53 PM
Has anyone found good places for jackstands on the 07/08 Outlanders? Same question for jacking points(especially with large based floor jack). Have to rotate my tires and haven't taken a look under mine yet.
Cuffy May 6, 2008 12:45 PM
RE: Jacking points / Jack Stands
I was going to jack mine up when i installed my hitch, but couldn't find any good spots to put a hydraulic jack. There's very few flat spots and the frame rails appear thin. The manual shows specific points for the OEM jack, but they didn't look so solid either...sits on a lip of sheet metal.
I'd like to hear what others didtoo.
roach May 6, 2008 12:49 PM
ORIGINAL: Cuffy
I'd like to here what others didtoo.
I use the OEM specified point from the manual to put my hydraulic jack to change my winter tire to my summer and everything was fine.
n0c7 May 6, 2008 11:53 PM
ORIGINAL: roach
ORIGINAL: Cuffy
Where did you place your jackstand on the other end while the jack was holding one end up?
HandyPal May 11, 2008 02:28 PM
I go to a rental garage with lifts to swap/rotate tires. Take my tools and get it done quick no mess.
roach May 11, 2008 07:06 PM
ORIGINAL: n0c7
ORIGINAL: roach
ORIGINAL: Cuffy
I did not use jackstand as I was changing one wheel at the time only use my hydraulic jack
OutlanderGT Jul 18, 2012 12:49 AM
I can't believe I looked through the manual and full of fun and some uesless info but I cannot find any information about where to place a floor jack and jackstands.
Obviously it the jackstands would go on the scissor jack point (if needed) but where to lift the vehicle with a floor jack?
Claude_A Jul 18, 2012 08:06 AM
1 Attachment(s)
See pic from the 2007 manual in one of the sticky
ccernst Jul 18, 2012 10:28 AM
I've used the hard point on the front that claud posted...never tried the rear.
I bought the lifetime tire rotation deal from firestone. so now I make them do it every 7.5k miles at no charge!! :D
OutlanderGT Jul 18, 2012 11:22 AM
So I would jack up the front, put 2 jackstands, then jack from the back put 2 jackstands.. Then I can proceed to rotate the tires or bleed the brakes?
I know people jack from the side but not sure if I want to do this, once you damage the rail on the side you have a hard time using the spare jack.
