-   Mitsubishi Outlander (https://mitsubishiforum.com/forum/mitsubishi-outlander-10/)
-   -   Jacking points / Jack Stands (https://mitsubishiforum.com/forum/mitsubishi-outlander-10/jacking-points-jack-stands-27347/)
Claude_A 07-18-2012 11:22 AM
Also to protect the lifting point I use a Hockey puck in the cup of the floor jack.
If you lift the front high enough using the side front point the rear will lift also high enough for you to change the wheel.
klas 08-01-2012 05:45 PM
Originally Posted by Claude_A (Post 285426)
See pic from the 2007 manual in one of the sticky
I am figuring this out as well. So the two bottom circles are the hard points for it?
OutlanderGT 08-01-2012 06:13 PM
Would be great to see the bottom of that pictures,
there are a few notches on the side rail area. It doesn't look like it is very strong and may get crushed.
Claude_A 08-02-2012 08:24 AM
2 Attachment(s)
The notches are there to secure the car emergency jack.
But the attached image show the two alternatives i.e. stands or floor jack.
Also protect the notch area by using a hard rubber padding. I use a Hockey puck, easy to find in Canada or the US at sport shops.
I use the front side rail and lift high enough to get the rear of the ground at the same time.
joeba 04-02-2013 05:11 PM
For jack stands, is that photo actually indicating that you are suppose to put the jackstands on the pinch-rails?
ruski 04-16-2013 05:31 PM
Quite surprising, but that's what it looks like.
OutlanderGT 05-31-2013 03:18 PM
Going to rotate tires on my car by putting jackstands on all 4s, hopefully things will go smoothly
I simply don't have a hockey puck or understand how to put the puck over a thin cradled area on top of a jackstand..
OutlanderGT 06-05-2013 10:38 PM
I was able to complete the job using the diagram jack points posted by claude. I jacked up the front put jackstands and then jacked the back, unfortunately the front tire started to touch the ground, since it has a large wheel gap and long suspension. Had to go back and raise the front some more.
Because the jack point in the front is almost near the bumper, it takes a very high jack, and the jackstands needed to be high as well.. The front is jackpoint is also not centered so the rise is uneven, it took a while to get all jackstands rested safely.
Dropping the car very slowly on jackstands, no damage noticable to the notched area, the dealer did more scratch and dent to it using their lift.
