K500 primer
Old Aug 17, 2007 | 09:44 PM
firebuck's Avatar
Default K500 primer
My wife and I just bought a set of side window deflectors for her 2007 outlander. In the install guide it tells us to use some 3m k500 primer on the leading corner of each front deflector. Does anyone know if we have to do this? My wife had deflectors on her lancer for 4 years without any problems and we did not have to use this stuff. I checked some of the local auto parts places but they don't have; any are there are substitutes available?
Thanks for any info and sorry for the strange first post.
Old Aug 18, 2007 | 01:01 PM
biscuit's Avatar
Default RE: K500 primer
Just wipe it down with a microfiber cloth and denatured alcohol and you'll be fine. They just want to make sure there is no wax, oil, dust etc on the surface. You can get denatured alcohol at any hardware store, great stuff to have around for cleaning plastics too.
Old Aug 18, 2007 | 02:46 PM
maharajah's Avatar
As biscuit says a microfiber cloth with some alcohol (I prefer 50/50 with water) will do the trick for making sure the surface is clean. Since I'm a bit ****, I normally follow with an adhesion promoter like 3M 06396 (which may be the same as the k500, I don't recall). I think I bought the promoter about a year or two ago from Hands on Tools.
EDIT: This stuff is pretty powerful, so use gloves in a well ventilated area.
Old Aug 18, 2007 | 02:57 PM
firebuck's Avatar
Thanks a lot for the help. I appreciate it.
Old Aug 18, 2007 | 06:46 PM
BoldlyGoingNowhere's Avatar
firebuck- Can you post back your opinion on the deflectors? Im curious as to whether it helps the booming when you dont have enough windows open.
thanks,
BGN
Old Aug 18, 2007 | 07:35 PM
rcpax's Avatar
Tips and photos on OEM mud guards installation w/o use of k500: http://outlander.freeforums.org/viewtopic.php?t=56
Old Aug 19, 2007 | 09:47 AM
Fisherman's Avatar
You could also use 3-M wax and grease remover if you can find it. It removes any grease and wax without damaging the paint.
Old Aug 19, 2007 | 11:50 PM
rdenis's Avatar
I don't think the K500 primer is available in NA - Mits issued TSB or some other communication saying to use a substitute if I recall.
