Keyless FOB reprogramming
Allright, so the girlfriend went to the dealer with the Outlander (2011 XLS - FAST key) to get an ebay-bought fob reprogrammed.
We bought the truck with a single key so a second one was necessary and I didn't see myself shelling out the 450$+tx for a new key. I got the key from a seller that said that the key was tested and fonctionnal, guaranteed to work. Used but in good condition.
So the dealer tried to reprogram it for 30 minutes and got back to my girlfriend saying that it can't be done as the key is either defective or it's been reprogrammed too many times and can't be anymore .... WTF !?!?!
Does a used key need to be flashed (or whatever) ? Is the dealer right in regards to the number of reprogramming ? Is the key locked ? Shouldn't the dealer be able to unlock it ... ?
The key could simply be faulty but I'm questioning the possibility to reprogram a used key.
Thanks
Thanks
Thanks Vadimus
Forgot to add; there is this site that has tons of fobs ... All used.
But, they offer flashing services for this particular key
https://www.keylessentryremotefob.co...20n%203btn.htm
Even these guys offer unlocking services :
Remanufacture Service for Mitsubishi Remote Insert Smart Key Fob OUC644M Key N | eBay
Try another battery... It might be bad or not sitting properly.
Did you change the battery because it wasn't working or did you change it because it had a low battery message?
If you slide the emergency key out and put the fob in backwards (square end in) and then turn the key while pushing the fob in it should start battery or not.
jnsluft
Jun 22, 2010 07:49 AM
Maximus99
Jun 23, 2007 06:55 PM
