LED Headlight conversion
2014 Mitsubishi Outlander SE
So I'm having this problem with the H7 LED bulbs I just ordered on Amazon. I researched the bulb size for the low beam and H7 was the correct size.
Now when I tried to install the bulbs I came to realize the locking teeth (the three prongs attached to the hardness plug) does not work for the LED bulb that has the wiring hardness attached.
I tried to find an adapter for the bulbs but I have not successfully found a pair.
Does anyone know how can I change the stock headlights to LED or where can I find an adapter or LED bulb that will work.
Thanks
Thanks
I have 2016 outlander se. Found Marsauto brand works great. They come with plastic adapters and even white gloves for installation. But also found that if you are able to remove the silver rings from the bulbs and seat them first (insert into housing and twist to lock), you can put the bulbs in and lock it pretty easily. And it feels secure.
theiss2200
Sep 12, 2019 08:07 PM
carid
Feb 13, 2017 07:23 AM
TVP
Apr 28, 2005 12:34 PM
