Melted rubber coating
Old Aug 3, 2019 | 01:33 PM
Karzen's Avatar
Default Melted rubber coating
Has anyone dealt with the rubber coating on the lever under the steering wheel? It melted into black goo. How do I clean it up?
Old Aug 4, 2019 | 08:17 PM
1960StudebakerHawk's Avatar
Thats wierd......is it getting super hot down around that lever? Got a hot lady driving your rig?
Maybe just clean it up with gas, and then put some wire heat shrink tubing on the lever and heat it to make it shrink up onto the lever? Or just good ole duct tape?
Old Aug 5, 2019 | 09:40 AM
Karzen's Avatar
Default Melted goo
Thanks. Maybe a little gasoline will helpful for a cleaner.
Old Jul 9, 2020 | 09:59 AM
dob1313's Avatar
Hi Karzen,
How its going?
I have the same problem with the lever, when its getting too hot outside.
Did you manage to fix the problem or did the lever got hard again when cooled down?
Thanks.
Old Jul 9, 2020 | 10:28 AM
Karzen's Avatar
Originally Posted by dob1313
Hi Karzen,
How its going?
Thanks.
Not really. I just wiped the whole mess off of the steel handle and forgot about it.
Old Jul 9, 2020 | 10:45 AM
dob1313's Avatar
Gotcha. Thanks Karzen. You have a great day!
Old Jul 9, 2020 | 12:45 PM
Extremero's Avatar
If this is about the steering wheel adjustment lever (under the steering wheel), mine is melted too (2008 Outlander).
Even during the winter was soft, bending and sticky and that black plastic/rubber messy compound is very hard to get off your fingers.
I was planning to put a shrink tube on the whole thing, shrink it and cut off the melted compound that comes out at the ends, but removing it completely is probably a better option.
bic007
Nov 22, 2014 10:28 AM
Garvinder
Feb 22, 2014 07:39 PM
EVO4L
Oct 5, 2008 07:30 AM
atown420
May 11, 2008 05:38 PM
BigPile
Sep 22, 2004 12:45 PM
