Metallic cicadas sound from one of the wheels
Old Sep 14, 2011 | 09:57 PM
ruski's Avatar
Default Metallic cicadas sound from one of the wheels
hsssssssssss
also sounds like metal polishing
Goes away when I apply brakes.
What could this be?
Also seems to go away after 5-10 minutes of driving.
Old Sep 16, 2011 | 01:39 AM
_93TSI_370+K_'s Avatar
I hate to say it, but you gave the answer in your post. Raise the car and safely support it with jack stands. Put the transmission in neutral. Rotate each wheel by hand and you will find out which brake is making the noise. Possibly an pad worn unevenly?????...like you said, the noise goes away when you apply the brakes. Ergo, check the brakes. And as you live in south Florida, I bet your rotors flash rust overnight. Have you had brake work done recently?
Old Sep 16, 2011 | 02:43 PM
ruski's Avatar
Thanks. No brake work done recently and the car only has 45K miles, too early for the brakes to go bad yet, no?
Old Sep 16, 2011 | 07:31 PM
milliesdad's Avatar
Check the brakes. Anything can happen.
Caliper hanging up-bad brake pad, ect.
Old Sep 16, 2011 | 08:38 PM
Default Front pads wear faster
Front brakes wear faster than rear brakes, count on it. If you have 45K on the brakes, it is time to check them anyway, especially the fronts.
Old Oct 21, 2011 | 11:48 PM
Default Any update on your noise?
ruski.......any update?
Old Oct 26, 2011 | 05:11 PM
ruski's Avatar
nothing yet, haven't had a chance
Old Nov 9, 2011 | 06:45 AM
lovemycar's Avatar
Feel and smell the wheels right after driving for a while. If one is hotter or smells different, you could have a sticking caliper.
Old Nov 12, 2011 | 02:46 PM
ruski's Avatar
So it was my pads getting low and the indicator was making the noise.
Replaced the pads today with some Raybestos professional grade ones.
I am surprised that the stock pads lasted less than 50K miles, with my wife driving locally.
By comparison, I just replaced the stock pads on my GTO after 6 years and 87K miles, and they still had a little material left on them.
Oh well.
Attached Thumbnails Metallic cicadas sound from one of the wheels-img00361-20111112-1215.jpg   Metallic cicadas sound from one of the wheels-img00362-20111112-1216.jpg   Metallic cicadas sound from one of the wheels-img00363-20111112-1221.jpg   Metallic cicadas sound from one of the wheels-img00364-20111112-1256.jpg
racerx55
1st Generation
Mar 21, 2007 09:25 AM
rallyendeavor
Jul 20, 2006 11:22 PM
bim6180
Jun 19, 2006 01:24 AM
novandar
Feb 5, 2005 04:04 PM
