Missing button on MMCS
Your service dept may be able to find you one lying around. It should be covered under your warranty if you have less than 12,000 miles. They may justreplace the whole unit.
I can't imagine the button would have gone far. If you cleaned the interior recentlyi'd check your vacuum too.
I'd still press themto fixit. It's a new car and if something just falls off it should be replaced, regardless of the cost to them. If it was abuse then i'd see them refusing to fix it, but i highly doubt you were banging the MMCS.
Duoh! Just over the limit, isn't that always the case. Most dealers will replace anything if under the 12K mark. You're pretty close though so maybe another dealer will help you out.
I'd try a local junk yard too for any wrecked Outties. Maybe they have one that had major damage to the dash and MMCS (otherwise they'd have pulled it out).Hopefully you couldfind the button you need and super glue it back on to yours.
Karmann
08-22-2011 01:13 PM
silvercoupe97
12-01-2006 09:09 AM
