Missing button on MMCS
Old May 21, 2008 | 05:53 PM
mightyOUTTIE's Avatar
Default Missing button on MMCS
Before I go to the dealer, I want to ask you guys on here first.
Does anyone know where to get replacement part for it? I got a missingMENU button. It either fell off or lost.
Old May 22, 2008 | 06:54 AM
Cuffy's Avatar
Default RE: Missing button on MMCS
Your service dept may be able to find you one lying around. It should be covered under your warranty if you have less than 12,000 miles. They may justreplace the whole unit.
I can't imagine the button would have gone far. If you cleaned the interior recentlyi'd check your vacuum too.
Old May 22, 2008 | 12:41 PM
they said they don't have it separatly.
argh now its going to be annoying to press the menu. I have a mini tool to insert and press the tiny button for the menu option.
Old May 22, 2008 | 12:46 PM
Cuffy's Avatar
I'd still press themto fixit. It's a new car and if something just falls off it should be replaced, regardless of the cost to them. If it was abuse then i'd see them refusing to fix it, but i highly doubt you were banging the MMCS.
Old May 22, 2008 | 01:55 PM
I have around 13,400 miles on it. They told me me have to replace the whole thing.
But i'll try another dealer. If doesn't work, I'll call Mitsu and see if they can get it.
Old May 23, 2008 | 07:32 AM
Cuffy's Avatar
Duoh! Just over the limit, isn't that always the case. Most dealers will replace anything if under the 12K mark. You're pretty close though so maybe another dealer will help you out.
I'd try a local junk yard too for any wrecked Outties. Maybe they have one that had major damage to the dash and MMCS (otherwise they'd have pulled it out).Hopefully you couldfind the button you need and super glue it back on to yours.
Old May 23, 2008 | 10:05 AM
tufduck's Avatar
whoa once the button is off you have to super glue it? Its not one of those buttons where it can snap back into place?
Old May 23, 2008 | 11:25 AM
Cuffy's Avatar
I'm not sure if he will have to superglue it or not...that was speculation. I was thinking the tab/post on the back had broken or something. I can't imagine it would have come off otherwise.
baat2
Mar 2, 2012 07:28 AM
Karmann
Aug 22, 2011 01:13 PM
trident
Jan 12, 2007 06:03 PM
silvercoupe97
Dec 1, 2006 09:09 AM
ncyankeealva
Apr 5, 2006 11:34 PM
