MMCS issues
Old Jul 29, 2009 | 02:11 PM
boricua_aoc's Avatar
Exclamation MMCS issues
I have an 07 LS that came with the 6cd changer. I recently traded my 6CD changer for for a MMCS of a 07 XLS and everything works with the exception to the navigation. When I initially installed it I had to get one of the plugs that was taped to the wiring bundle from the vehicle and added to the MMCS. the nav shows up but every time I start the vehicle it says it is Jan 1, 05. the map on the nav moves ans the vehicle moves but Im not in the right place.
I believe that I'm missing some kind of antenna in order for it to work.
Thanks
Old Jul 29, 2009 | 06:59 PM
rip14's Avatar
There is a separate GPS antenna. Did you install that?
Old Jul 29, 2009 | 08:01 PM
I guess that is what Im missing but when we removed it I didn't see it. Do you know where is it located?
Old Jul 30, 2009 | 02:58 AM
Ceram's Avatar
Smile
It's located directly in front of the compartment above the MMCS. You find the screw's that hold the frame in place inside the compartment. Remove these first, and then remove the part of the dashboard. You will find the GPS antenna fasten to a metal frame inside.
Good luck:-)
Old Jul 30, 2009 | 05:51 AM
Thumbs up
Thanks, I will take a look there.
Old Aug 2, 2009 | 12:09 PM
Does anybody have the part # for the gps receiver(antenna) and the best place to buy this from?
Old Aug 2, 2009 | 05:37 PM
rip14's Avatar
You may want to try mitsubishipartspeople.com
Many people have bought there. See this thread:
https://mitsubishiforum.com/forum/sh...ad.php?t=33176
Also, many people like mitsupartsman.com
You can contact him at mitsupartsman@gmail.com
LouisASX
Oct 28, 2012 01:10 AM
Ghost2501
Aug 10, 2007 09:20 PM
Arcueil
Jun 4, 2004 05:39 PM
cooley
Apr 1, 2004 01:59 AM
DarkrealmX
Feb 15, 2004 07:47 AM
