MMCS Question
Old Sep 20, 2013 | 01:17 PM
11SE2HEAR's Avatar
Default MMCS Question
I recently picked up a full MMCS system for my '11 Outie that currently has the OEM Rockford system. I received the main MMCS unit, the mounting bracket, the bezel, the harness, the environmental unit that mounts underneath the MMCS cage, the GPS antenna with the bracket and the operating manual. Everything is pretty much plug & play and worked just fine when I powered it up. However I'm stumped as to where in the dash the GPS antenna/bracket assembly mounts to under the dash. I could not find any diagram or previous threads in the forum showing where it goes. It has to be pretty simple, the antenna harness wasn't that long. So I'm hoping I don't have to tear the dash apart. Any help here?
Old Sep 20, 2013 | 08:52 PM
quadcam's Avatar
Under the top cover of the centre dash section.
Old Sep 22, 2013 | 08:30 AM
11SE2HEAR's Avatar
I will take a look at it again. I figured the antenna would be mounted just above the radio because of the length of the antenna wire. So the antenna mounts to the inside of the dash, not on top of the MMCS cage, right? Would that center cover of the dash need to be removed to install the antenna bracket to it?
Old Oct 18, 2013 | 10:13 AM
Vadimus's Avatar
Yes. Two black screws to go away, than pull it upward. The mount place is front right side of the opening.
Old Oct 18, 2013 | 04:19 PM
11SE2HEAR's Avatar
Guess I forgot I posted the question earlier. I found that same diagram myself. So yes, I did have to remove two Phillips screws on the center section of the dash and pop that top cover off....carefully. Everything fit into place perfectly and the it's all working perfectly. The whole install took hardly any time at all once I saw the diagram.
Old Oct 18, 2013 | 06:30 PM
Vadimus's Avatar
Hey, you're the guy we're waiting for! Share you maps if they are anything newer than this:
Old Oct 19, 2013 | 08:13 AM
11SE2HEAR's Avatar
Here's the version mine came with.....
Old Oct 20, 2013 | 07:55 AM
Vadimus's Avatar
It is definitely newer!
Could you please upload maps somewhere?
Old Oct 20, 2013 | 09:00 AM
Vadimus's Avatar
Here are the files/dir we need:
Code:
10/05/2007  12:06 PM     2,091,376,960 0.1
10/05/2007  12:36 PM     1,695,952,896 0.2
15/05/2007  02:49 AM             4,096 ALLDATA.KWI
26/03/2007  04:12 AM             7,686 CTRYMETA.CSV
16/05/2007  08:53 AM    <DIR>          IDX
19/03/2007  12:16 PM             2,444 INDEXDAT.KWI
10/05/2007  12:40 PM        71,733,632 PAR_MNG.ME
08/05/2007  05:26 AM           271,176 PARAM2.ME
10/05/2007  12:37 PM       819,282,976 PARCEL.KWI
02/04/2007  01:39 AM       852,599,936 REGION.KWI
13/03/2007  08:38 AM        39,407,642 VOICE001.ME
14/03/2007  05:39 AM        83,396,096 VOICE002.ME
Old Oct 20, 2013 | 10:58 AM
11SE2HEAR's Avatar
Not really sure how to go about doing that. I'm pretty sure there's a newer version out there.
