MMCS Rear Entertainment
Old Aug 1, 2012 | 03:47 PM
Gen-8's Avatar
Default MMCS Rear Entertainment
Hey guys could you please tell me why my RES won't turn on? Does it need etacs programming or something..
My MMCS is j-01 and JDM spec
Old Aug 2, 2012 | 03:09 PM
Gen-8's Avatar
Bump?.
Old Aug 4, 2012 | 08:18 PM
Gen-8's Avatar
Bump please
Old Aug 4, 2012 | 10:18 PM
OutlanderGT's Avatar
It may have to be reprogrammed as I believe the MMCS will show options for rear entertainment when equipped from factory.
Old Aug 5, 2012 | 04:02 AM
Gen-8's Avatar
How do I reprogram that bud? It's but hard when its japaneese thi
Old Aug 5, 2012 | 07:16 AM
jsrd's Avatar
Look here to check your electrical connections,
https://mitsubishiforum.com/forum/mi...vd-mmcs-19785/
I installed my RES after purchase my Outtie and do not require any reprogramming. . .
Old Aug 5, 2012 | 04:16 PM
Gen-8's Avatar
I have the wiring loom that plugs from the res to under passenger seat,but still nothing.
Old Aug 6, 2012 | 02:25 AM
Gen-8's Avatar
heres some images to show the wiring loom,plugs,screen shots of the hidden setup menue etc
Old Aug 8, 2012 | 04:39 AM
hotponyshoes's Avatar
Do you have the RES with the DVD player built into it?
If you do then the dvd player should work if it is connected to mmcs or not.
If you turn the key on and put a DVD in it should start to play.
If not I would check the power to the RES
If it does play then we can look at checking connection to the mmcs after but make sure that the RES does actually work first
Old Aug 8, 2012 | 02:28 PM
Gen-8's Avatar
It was tested before removal but does not do anything in our car, I thought it should atleast fireup but no go
