Mp3 player wiring for Outie LS
Old Jun 19, 2010 | 01:14 AM
FiReBReTHa's Avatar
I wanted to see what you guys think, i have laying around the house is a
MZ360224EX
http://www.outlander-forum.de/phorum...MZ360224EX.pdf
you think i can rig it to be used in my wifes outie?
seems like the only difference is that it uses 2x grounding points instead of one and the orange is the same as red connection.
Old Jun 19, 2010 | 05:14 PM
FiReBReTHa's Avatar
NM, the second grounding point is a seperate wire so I left that out.
I then used the Orange wire to take place of the Red and then used the same pinout as
http://forums.evolutionm.net/lancer-...mp3-cable.html
the wires are a different color coding on the 2007 outlander SE but I figured that the connections to the headunit would be the same and they were.
The wife is happy because then she can use her Tmo slide and stream pandora tothe car.
[img]
Uploaded with ImageShack.us[/img]
Old Sep 9, 2013 | 08:54 PM
T0b3y's Avatar
So what do I do if my C15 already has wires where the drawing shows that I should hook up the MIT-POD?
Old Nov 24, 2013 | 05:32 AM
Fjelle's Avatar
Hi, I have wires where I must put those cables in? What to do?
Old Jan 9, 2014 | 02:16 PM
Ladisv6's Avatar
hi, o if I will connect my iphone to the connector in the back of the factory radio - then I don't need a MIT-POD connector? Can I solder pins to the 3,5 jack cable only?
Old Jan 9, 2014 | 02:44 PM
Vadimus's Avatar
Yes, but before that make sure you don't already have in the middle armrest storage bin.
Old Jan 9, 2014 | 05:01 PM
Ladisv6's Avatar
it is there. but I not able to buy opposite connector. Can I cut the storaged connector and solder wires to wires?
Old Jan 9, 2014 | 06:20 PM
Vadimus's Avatar
Sure, why not?
Old Jan 10, 2014 | 02:41 PM
Ladisv6's Avatar
because 3,5 jack cable has a shielding/screening (I don't know the real term) and cables in armrest don't have it. How to solder them together?
Old Jan 10, 2014 | 03:35 PM
Vadimus's Avatar
In ideal world - yes. But Mitsu decided it is not critical. Use tester to find a ground among those wires, and connect it to 3.5 jack cable's shield.
Moreover, my rearview camera is connected by a 1 wire only (using car chassis as a ground) and still it works fine.
Steven.WK
Nov 5, 2007 10:23 AM
audioqueso
Sep 3, 2007 09:25 AM
myspacemyk
Oct 23, 2006 06:50 PM
GreddyBooster
Sep 8, 2005 01:08 PM
sidewaysjack
Nov 21, 2003 03:17 AM
