Multiple codes
Old Apr 7, 2022 | 08:22 PM
Bigjuniortrucker's Avatar
Default Multiple codes
My girlfriend has a 2015 Mitsubishi Outlander, 2.4L. Yesterday morning she left for work and made it about 1/4 mile and had to turn around to come back home. It started running very roughly, the service engine soon light was flashing! I used my scanner to scan it. The P0302 code (cylinder 2 misfire)popped up. I decided with 130,000 miles that I would change the spark plugs. It needed rear brakes too. I replaced all of the spark plugs and changed the brakes. Once I put everything together, I had to use our battery jump box to start it. The car started. I let it run for a few minutes. Then it all started again. The scanner said code P0300 (random cylinder misfire) this time. This morning I took all of the plugs back out, put them back in, and checked all of the connections. I had to use the jump box again but once it started it through code P0302. I switched the coils on cylinders 2 & 3! I restarted it and it still showed the P0302, and It also through codes B1476, B1558, B210A, B2353, B1A25, B1A35, B210D, and B1691. I looked them up, but I can't remember what all of them are. Some are low voltage things. I thought it was maybe the battery, but then it began to start without the booster. Any ideas are greatly appreciated!
Old Apr 7, 2022 | 09:23 PM
kev994's Avatar
I’d start with the battery since it sounds like it needs one anyway.
Old Apr 7, 2022 | 10:16 PM
Thank you very much!
Old Apr 9, 2022 | 09:00 PM
Update, I replaced the battery. Fixed all of the low voltage codes. Still running poorly and throwing p0302. I've swapped plugs around and at different times swapped coils around. I did notice that when I swapped the coils for cylinders 1 & 2 that it seemed to run worse. But it still says code p0302. Any idea how long it should take for the computer to update itself on a new code?
Old Apr 14, 2022 | 11:21 AM
kev994's Avatar
It’s apparently a #2 cylinder misfire. I’m 99% sure this is the same engine as the lancer so any google info you can find on it should be good.
Bigjuniortrucker
Apr 7, 2022 08:22 PM
milk
Mar 24, 2021 03:25 PM
WVHIGHLANDER65
Nov 4, 2014 12:27 AM
galant00owner
May 24, 2012 07:21 PM
mitsu01gs
Sep 12, 2007 07:30 AM
