My 2015 ASX SE PLUS :)
I want to share the upgrades I'm doing in my 2015 ASX, which I have 3 months and am very happy with it. I reused many accesories of my previous car, 2007 Outlander, but others are completely new, such as this sharkfin antenna.
OEM part, active, part number MZ5999**, delivered to the color of my car; the hardest part of the installation was to remove the side plastic in te cargo area to access the antenna. The change is welcome, the look is great, and the reception is as good as like as the ugly mast antenna. Here pics
![Smile](https://mitsubishiforum.com/forum/images/smilies/smile.gif)
One accessory that I had in my previous 2007 Outlander, but this is new, is the Sigma Speed Hood damper kit, made specifically for the ASX. It includes all hardware necessary, so it is a plug&play installation, and it took 15 minutes of work. I removed the standar rod, and the hood rises a little more with the damper. Here pics
isn´t an OEM accessory, but it has very good finishing and good quality, and the lighting is a beautiful blue, and ASX logo has a very nice "dot matrix" finish. Has only one harness, so I started with front door passenger side, then back door right side, then back door left side, and finally with the driver's door. For this reason I had to remove the backseat to pass the harness, although you can try another option to route the harness, it all depends on how you want to do ![Wink](https://mitsubishiforum.com/forum/images/smilies/wink.gif)
here pics
here pics
the pedals are GT version, and I the reuse of my previous 2007 Outlander
I bought these covers because I wasn´t happy with the "asymmetry" in the instrument panel, because while the center console had ornaments in silver finish, the outlet air vents next to the front doors were in black plastic; Now, the instrument panel looks better
this was my first update, replace standard bulbs by LED lamp, which recovered from my 2007 Outlander. These lamps are sold by Mitsubishi, and have a great performance
