My 2015 ASX SE PLUS :)
Old Oct 24, 2015 | 06:29 AM
jsrd's Avatar
Default My 2015 ASX SE PLUS :)
I want to share the upgrades I'm doing in my 2015 ASX, which I have 3 months and am very happy with it. I reused many accesories of my previous car, 2007 Outlander, but others are completely new, such as this sharkfin antenna.
OEM part, active, part number MZ5999**, delivered to the color of my car; the hardest part of the installation was to remove the side plastic in te cargo area to access the antenna. The change is welcome, the look is great, and the reception is as good as like as the ugly mast antenna. Here pics
Attached Thumbnails My 2015 ASX SE PLUS :)-20150918_124704.jpg   My 2015 ASX SE PLUS :)-20150918_124719.jpg   My 2015 ASX SE PLUS :)-20150919_094041.jpg   My 2015 ASX SE PLUS :)-20150919_101649.jpg   My 2015 ASX SE PLUS :)-20150919_103257.jpg
My 2015 ASX SE PLUS :)-20150919_103359.jpg   My 2015 ASX SE PLUS :)-20150919_174349.jpg   My 2015 ASX SE PLUS :)-20150919_174448.jpg   My 2015 ASX SE PLUS :)-20150919_174509.jpg
Old Oct 24, 2015 | 06:55 AM
jsrd's Avatar
Default Hood damper kit
One accessory that I had in my previous 2007 Outlander, but this is new, is the Sigma Speed Hood damper kit, made specifically for the ASX. It includes all hardware necessary, so it is a plug&play installation, and it took 15 minutes of work. I removed the standar rod, and the hood rises a little more with the damper. Here pics
Attached Thumbnails My 2015 ASX SE PLUS :)-20151013_072348.jpg   My 2015 ASX SE PLUS :)-20151013_073022.jpg   My 2015 ASX SE PLUS :)-20151013_074524.jpg   My 2015 ASX SE PLUS :)-20151013_075032.jpg   My 2015 ASX SE PLUS :)-20151013_075041.jpg
My 2015 ASX SE PLUS :)-1283662951-3.jpg
Old Oct 24, 2015 | 09:20 PM
caskey_b's Avatar
Looks good!
I'd like to eventually do the hood strut.. but I have a LOOOONG list of other things that I want to do first
Old Oct 25, 2015 | 12:13 AM
jsrd's Avatar
Default Door sill scuff plate
isn´t an OEM accessory, but it has very good finishing and good quality, and the lighting is a beautiful blue, and ASX logo has a very nice "dot matrix" finish. Has only one harness, so I started with front door passenger side, then back door right side, then back door left side, and finally with the driver's door. For this reason I had to remove the backseat to pass the harness, although you can try another option to route the harness, it all depends on how you want to do
here pics
Attached Thumbnails My 2015 ASX SE PLUS :)-20151008_152047.jpg   My 2015 ASX SE PLUS :)-20151013_082016.jpg   My 2015 ASX SE PLUS :)-20151013_082043.jpg   My 2015 ASX SE PLUS :)-20151013_082932.jpg   My 2015 ASX SE PLUS :)-20151013_134944.jpg
My 2015 ASX SE PLUS :)-20151013_135003.jpg   My 2015 ASX SE PLUS :)-20151013_161651.jpg   My 2015 ASX SE PLUS :)-20151013_161719.jpg   My 2015 ASX SE PLUS :)-20151013_163440.jpg
Old Oct 25, 2015 | 01:04 AM
caskey_b's Avatar
where did you tap into power at?
also.. what pedals are those? I'll be getting some, just haven't decided what yet, but I do like those
Old Oct 25, 2015 | 01:40 AM
jsrd's Avatar
look in the attached pics: yellow wire= mass / red wire=12 volts map lights
Attached Thumbnails My 2015 ASX SE PLUS :)-imagen1.jpg   My 2015 ASX SE PLUS :)-imagen2.jpg
Old Oct 25, 2015 | 01:54 AM
jsrd's Avatar
the pedals are GT version, and I the reuse of my previous 2007 Outlander
Old Oct 25, 2015 | 04:02 AM
jsrd's Avatar
Default MZ314463 silver finish cover outlet air vents
I bought these covers because I wasn´t happy with the "asymmetry" in the instrument panel, because while the center console had ornaments in silver finish, the outlet air vents next to the front doors were in black plastic; Now, the instrument panel looks better
Attached Thumbnails My 2015 ASX SE PLUS :)-vistas.jpg   My 2015 ASX SE PLUS :)-20151010_134755.jpg   My 2015 ASX SE PLUS :)-20151010_140953.jpg   My 2015 ASX SE PLUS :)-20151010_141014.jpg   My 2015 ASX SE PLUS :)-20151010_141056.jpg
Old Oct 25, 2015 | 04:10 AM
jsrd's Avatar
Default WeatherTech floor mats
my new set; for me, the best mats availables
Attached Thumbnails My 2015 ASX SE PLUS :)-20151008_154524.jpg   My 2015 ASX SE PLUS :)-20151008_154708.jpg   My 2015 ASX SE PLUS :)-20151008_155940.jpg   My 2015 ASX SE PLUS :)-20151008_155911.jpg   My 2015 ASX SE PLUS :)-20151008_160646.jpg
Old Oct 25, 2015 | 04:23 AM
jsrd's Avatar
Default Update bulb for interior lamp
this was my first update, replace standard bulbs by LED lamp, which recovered from my 2007 Outlander. These lamps are sold by Mitsubishi, and have a great performance
Attached Thumbnails My 2015 ASX SE PLUS :)-20150822_173920.jpg   My 2015 ASX SE PLUS :)-20150822_173435.jpg   My 2015 ASX SE PLUS :)-20150822_173352.jpg
