N-02 Aux-in wiring
N-02 Aux-in wiring
I'm having troubles hooking in aux-in to an N-02 MMCS ..
I have no loom, so all connection points need to be with ref to the back of the MMCS ..
I've used http://i339.photobucket.com/albums/n446/jsrd/C7.jpg as a basis for the wiring , but no go - no aux button in the UI..
Anyone got any suggestions ?
I believe it's an ETACs option to enable the aux-in function..
Almost nothing on that car works by just connecting the hardware if you don't tell the computer it's there...
You can probably get your stealership to enable it for a few bucks.
Vad will know for sure if it's an ETACs option or not.
Video Input shows as N/A on both units ..
Weird, there's no known "detection" wires like those enabling rear view cam.
The only way I know to have Aux disabled is to connect rear seat display.
Haven't checked ETACS settings though.
Kinda need to keep the 30 version on - it's not exactly a "standard" build.
Well I have Aux working fine - let me know what should I check.
What lines do you have connected in c106 ?
Are you sure that is the right pinout - I don't see a video-in pin there ?
Have a looksie here:
Second Generation Outlander Stereo Wiring - Mitsubishi Wiki
"NOTE: You can use the video output from pin 45 and 56 to make an MMCS video out RCA connector. Likewise, you can use 57 and 58 to get video to the MMCS (aux video in). The audio will come from the AUX IN audio from the connector below."
