N-02 Aux-in wiring
Old Feb 12, 2014 | 10:33 AM
Otaku's Avatar
Default N-02 Aux-in wiring
I'm having troubles hooking in aux-in to an N-02 MMCS ..
I have no loom, so all connection points need to be with ref to the back of the MMCS ..
I've used http://i339.photobucket.com/albums/n446/jsrd/C7.jpg as a basis for the wiring , but no go - no aux button in the UI..
Anyone got any suggestions ?
Old Feb 12, 2014 | 11:33 AM
Vadimus's Avatar
Here is the pinout:
However, I do not think Aux wiring is being checked by MMCS. What loader version are you using?
Old Feb 12, 2014 | 11:34 AM
Guyfromhe's Avatar
I believe it's an ETACs option to enable the aux-in function..
Almost nothing on that car works by just connecting the hardware if you don't tell the computer it's there...
You can probably get your stealership to enable it for a few bucks.
Vad will know for sure if it's an ETACs option or not.
Old Feb 12, 2014 | 11:44 AM
Vadimus's Avatar
Is Aux active here?
Old Feb 12, 2014 | 11:49 AM
Otaku's Avatar
Originally Posted by Vadimus
Here is the pinout:
Hrm - 30.94/1.10 UM ( N-02 ) and 10.00.17/1.10 EM-CTR (C-01).
Video Input shows as N/A on both units ..
Old Feb 12, 2014 | 12:00 PM
Vadimus's Avatar
Well, try to update it to at least 41.02 (the oldest I tried)...
Weird, there's no known "detection" wires like those enabling rear view cam.
The only way I know to have Aux disabled is to connect rear seat display.
Haven't checked ETACS settings though.
Old Feb 12, 2014 | 01:36 PM
Otaku's Avatar
Thats why I hooked up the citroen one: it's not a version problem..
Kinda need to keep the 30 version on - it's not exactly a "standard" build.
Old Feb 12, 2014 | 02:16 PM
Vadimus's Avatar
Well I have Aux working fine - let me know what should I check.
Old Feb 12, 2014 | 02:27 PM
Otaku's Avatar
What lines do you have connected in c106 ?
Are you sure that is the right pinout - I don't see a video-in pin there ?
Old Feb 12, 2014 | 02:37 PM
Guyfromhe's Avatar
Have a looksie here:
Second Generation Outlander Stereo Wiring - Mitsubishi Wiki
"NOTE: You can use the video output from pin 45 and 56 to make an MMCS video out RCA connector. Likewise, you can use 57 and 58 to get video to the MMCS (aux video in). The audio will come from the AUX IN audio from the connector below."
