Need help!! Quick!
Old May 15, 2010 | 07:57 PM
DaBearSox's Avatar
Default Need help!! Quick!
SO i am installing a new pioneer head unit with an xm reciever and steering wheel control. The steering wheel control is the Axxess ASWC.
So i have the XM in and working and the radio working however the manual for the 2009 outlander to install the steering wheel control found here: http://www.axxessinterface.com/steer...ntrol_new.aspx
says to connect this color where to the wire at pin 19....well there is no wire in the car's harness in pin 19....What is the color of the steering wheel control wire in the cars harness....i know it has to be there cause it worked with the factory radio. Thanks!
Old May 17, 2010 | 12:49 PM
DaBearSox's Avatar
So basically the picture that the instructions give is opposite so it is really confusing to hook up the steering wheel control. After a few calls to tech help it was figured out that the small black wire is the steering wheel control, and the small blue wire is the steering wheel control ground. Quite confusing since the other black wire in the harness is the ground as well....
These weren't included in the harness so I had to cut and solder straight into the vehicle harness...not ideal but I don't think i will ever be using the factory radio again.
After i got the right wires it works great, with no delay.
chenner32
Apr 11, 2012 07:57 PM
nabilnathir
May 6, 2009 02:59 PM
htgrlz4me
Aug 7, 2007 01:08 PM
deedeekh
Jun 4, 2007 09:34 AM
Binx420
Mar 14, 2005 01:08 AM
