Need help with steering wheel controls????
On my '07 Outlander, the steering wheel controls for the radio and bluetooth on the left side of the steering wheel are not working. The cruise control on the right side works fine. Has anybody seen this problem, and if yes, what did you do to fix it? Anybody have any suggestions beside taking it to the dealer - they won't help with any advice at all and want $250 just to check it out + parts and installation time. UGH!!
Thanks |
Check the resistance between the wires coming from the steering wheel controls to the stereo:
Second Generation Outlander Stereo Wiring - Mitsubishi Wiki Make sure it changes when you press a button/isn't an open circuit. Then download the service manual and check for the proper resistance per button. |
Thanks ivanz for your help. I'm going to have to search out a pro to do this job. I was hoping it would be something simple, but no joy.
are these the factory controls? did you add a steering wheel control for an aftermarket radio?
I had issues but it was with all aftermarket equipment. Ended up doing it myself because i went to an inexperienced installer -___- |
I had a problem a while back where the volume up and volume down buttons on the steering wheel would only turn the volume down. Could not turn the volume up at all using the steering wheel controls. I hit it a few times and it seems to fix itself. Caveman logic I know, but these are first world problems.
Originally Posted by MB07
(Post 290155)
I had the same issue a few months ago...It was intermittent, but obviously not working right. Mine was still under warranty. Said it needed a new relay switch. Works fine now..... Hope that helps. |
Originally Posted by xOutlanderFiendx
(Post 290149)
(Post 290155)
Originally Posted by newoutlanderfan
(Post 290172)
Hope that helps. |
It's easy to check if you are comfortable to remove the stereo (which is a 5 min job). You just need a $10 miltimeter that measures resistance....just make sure each time you press the button the value on the thing matches what the service manual says.
Not sure what a switch has to do with it, it goes from the wheel, through a clock spring, to a wiring harness going into the back of your stereo. Don't believe there is any relay involved....that may have been some radio power supply issue. |
| All times are GMT -5. The time now is 03:14 AM. |
