New 2010 Outlander Stalling at stop sign
I just bought a new 2010 Outlander (250 km on it). The car stalled at a stop sign while coming back from the dealer. Then two days after, again, while slowing down and turning at low speed.
It seems like the idle is going to low (below 500 rpm) when the transmission "idle neutral logic" kicks in and stall the engine. In fact mitsubishi is clamming some gas saving with this new gizmo, for sure if the engine stall you will save some gas.
Went to the dealer, no code in the computer, they have no clue. It looks like if the computer can not maintain the rpm
I saw a similar post on that a year ago, but I was wondering if the dealer or mitsubishi found a solution.
I am quite feed up with this car and about to give back the keys...
Someone having the same problem?
I'd check the air filter box. It could be opened.
Its probably a software issue with Idle Neutral Logic. Dealership needs to take a look at it. Couple of people were complaining about it at the beginning when Mitsubishi just introduced idle neutral logic but from what I understand software was modified and they took care of it.
Sanguinius
Jun 1, 2026 01:19 AM
Cmorr
Mar 10, 2012 05:23 PM
