Noise when accelerating on 2013 Mitsubishi Outlander Sport SE
Old Jul 25, 2024 | 09:50 PM
7CAM's Avatar
Default Noise when accelerating on 2013 Mitsubishi Outlander Sport SE
Hello i was hoping someone can point me in the right direction
When idling you can hear a whining noise coming from the passenger side of the engine. When I accelerate, the whining increases.
While driving
https://streamable.com/yzfkwc
Idling
https://streamable.com/irpcig
Old Jul 26, 2024 | 04:23 PM
Outlaander's Avatar
How many kms or miles on the odometer?
By "humming", do you mean that whining sound as you accelerate?
Old Jul 26, 2024 | 07:25 PM
7CAM's Avatar
yeah i did mean whining
the car has 146,000 miles on it
Old Jul 27, 2024 | 10:14 AM
Outlaander's Avatar
I'm leaning toward the CVT being the source of the whining sound.
Is there any difference in the whining sound (while the vehicle's engine and transmission are completely warmed up, the vehicle is not moving, and you do NOT touch the accelerator pedal) between putting the transmission in neutral and putting the transmission in drive while depressing the brake pedal to prevent the vehicle from moving? In other words, with the engine idling, depress the brake pedal, do not touch the accelerator pedal, and then shift back and forth between D and N and see if this affects the whining sound.
Then, with the enging running and transmission in Drive, press the brake pedal to prevent the vehicle from moving and slightly press the accelerator to increase engine RPM a little bit. Does doing that affect the whining sound, if at all?
Old Jul 31, 2024 | 05:10 PM
7CAM's Avatar
Just had a chance to test the car and I didn’t notice any change in the sound in either case.
thanks for the help
Old Jul 31, 2024 | 06:15 PM
7CAM's Avatar
Drove it around a little more and got a “transmission service required“ alert…
Old Aug 4, 2024 | 07:01 PM
Truwarrior22's Avatar
Any luck diagnosing the issue?
Old Aug 8, 2024 | 11:24 PM
7CAM's Avatar
Not yet, haven’t had time to take it to a shop
Old Dec 10, 2024 | 08:46 AM
Nickelson155's Avatar
I'm having the same issue. The sound in your videos is identical to mine. Did you ever find out what it was?
Old Jan 4, 2025 | 08:25 PM
gabeb's Avatar
Get a $20 code reader to diagnose the transmission code. With a CVT, it's never good. The whinning could be the AC compressor. Mine got so bad it got embarrassing around people and had to replace it.
DarrenC
Jan 16, 2023 09:12 AM
billyhoyle
Aug 4, 2022 03:44 PM
Sergio Taran
Jan 23, 2020 03:03 AM
raptornexus
Sep 1, 2014 09:03 PM
Ray00
Dec 27, 2004 04:30 PM
