O7 xls v6 differential fluid fill quick solution?
Hello all and a happy Fourth of July.
I'm going to change out the transfer case and differential fluid today. Picked up Lucas 75 90 synthetic fluid. Purchase the transfer fluid pump but haven't opened it yet. Looking at the nozzle on the bottle I was just wondering if anyone has simply pushed clear tubing on to the nozzle ,held it into the filler hole and squirted the fluid in? I would assume as long as the tube is above the fluid level in the hole no fluid will be drawn back into the bottle. So long as the car is on a flat surface, I would assume you just fill it till it spills out?
Melvin Cordero Sanchez
07-28-2013 05:06 AM
jpardinas
10-19-2005 11:30 AM
