OEM xenon light control / HID ballast with igniter
Old Jun 19, 2012 | 10:34 PM
fiestataz's Avatar
Default OEM xenon light control / HID ballast with igniter
I am just wondering how difficult/easy to install the OEM xenon light control units / HID ballasts with igniters to a NON-HID equipped 2010+ Outlander, and most importantly to mod to work like an OEM HID headlights, i.e. with DRL on, low bean, and high bean??
Is it possible? Has anyone done this before?
I knew some uses aftermarket kit, and need to bypass or have to deal with the DRL issue....
Thanks a lot
Old Jun 22, 2012 | 02:33 PM
fiestataz's Avatar
here's the oem hid, anyone here?
Old Jun 25, 2012 | 12:18 PM
fiestataz's Avatar
is this feasible, anyone?? Thanks
Old Jun 25, 2012 | 12:40 PM
Vadimus's Avatar
HID headlights need lenses, you need the entire headlight assembly for HID retrofit.
Once you get those, it is mostly plug and play.
However, some settings in ETACS need to be changed for proper work of HIDs.
Old Jun 25, 2012 | 08:44 PM
fiestataz's Avatar
Thanks Vadimus. Do you mean the whole headlight assembly? Does all the after market kit like the picture above, and just need to swap the regular bolt with the HID bolt with the ballast and igniter? Sorry, I am just confused.
Old Jun 26, 2012 | 05:18 PM
ryandlor's Avatar
u need projector lenses, its a hold new headlight unit, or you can buy a retrofit kit for around $300.
batman47
May 28, 2013 12:51 PM
kakaraj
4th Generation
Jan 5, 2009 04:13 PM
itoig
Jan 14, 2008 10:40 PM
XFACTOR
Aug 23, 2005 12:11 AM
ixwesleyxi
May 24, 2005 09:02 PM
