outlander 06 hard to start
Old Nov 14, 2015 | 08:40 PM
outlander06's Avatar
Default outlander 06 hard to start
my outlander 06 is hard to start after refuelling.and when it does it idles up and down.have a check engine light on.try to refuell with motor running but when i remove the gas cap it stalled.
Im baffle...
Old Nov 15, 2015 | 09:21 AM
Guyfromhe's Avatar
Does it run/start perfectly when you start it except for when you refueled?
Can you get the check engine code scanned and post the code?
Old Nov 16, 2015 | 08:29 AM
yes it runs perfectly otherwise .will get it scan and post the code later. Thanks
Old Nov 17, 2015 | 09:35 AM
jimmyrinse's Avatar
Im baffle...
Is it only after refuelling or if you leave it and do a cold start do you have the same problem?
Old Nov 18, 2015 | 04:24 PM
only after refuelling. got a code #0171 that said vaccuum leak
Old Nov 18, 2015 | 10:10 PM
Guyfromhe's Avatar
I wonder if your gas cap isn't sealing properly... Are you making sure you put it on tightly? Can you smell gas at all when it's closed?
Old Nov 19, 2015 | 04:13 AM
jimmyrinse's Avatar
Do you have the same problem then if you just take the fuel cap off when it's stood and simply put it back on then try and start?
Old Nov 19, 2015 | 09:13 AM
the gas cap is always tight,no smell of gas.
to jimmyrinse did not try that but i will and post my answer later .thanks
Old Nov 20, 2015 | 12:48 PM
did remove the gas cap and install it again and it started fine but then when i stopped at the end of the driveway it stalled and was turning awile before it started again.
Old Nov 20, 2015 | 06:28 PM
Guyfromhe's Avatar
Could have something to do with the evap system...
