Outlander 07 All-Wheel Control with Advanced 4-Wheel Drive
#42
RE: Outlander 07 All-Wheel Control with Advanced 4-Wheel Drive
Hi,
Hope I'm not beating a dead horse here, but there is something that's still not clear to me...
What if, say, both right wheels were off the road, or on slippery surface? Would they then both be spinning, i.e. leaving the car immobile (assume open diffs at both front & rear).
Or, would this little bit of info make any difference, allowing the car to move forward:
"The traction control portion of ASTC provides a "virtual" limited-slip differential effect by helping to prevent wheel spin during start up and acceleration in slippery conditions. Even if the driver has not selected 4WD Auto or 4WD Lock modes on a 4WD Outlander model, front wheel spin can be controlled under a variety of conditions. Since a mechanical limited-slip differential is not required, weight is reduced."
Got this from Mitsubishi Media Newsroom
Very curious about this, as I'm about to purchase an outie...european diesel, if it makes any difference :-)
Cheers,
-Morten
Cheers,
-Morten
#44
ORIGINAL: zontarh
Where abouts in Europe are you? I'll be ordering mine soon too, could do with some feedback on that diesel engine!
This would be Oslo, Norway. I originally thought that there'd be a 2.2 ltr diesel with automatic, but later found out the automatic will only be available on a 2.4 ltr petrol :-(
With Norwegian taxes, I'll stick with the VAG 2.0 ltr manual shift. Which I hear performs just fine :-)
Cheers,
-Morten
#45
I've had a test drive in it and it drives real smooth and torquey although a little noisy, but what I want is the true MPG, official figures in comparison to the competition are excellent.
#46
ORIGINAL: morten
Hi,
Cheers,
-Morten
Hi,
Cheers,
-Morten
#47
ORIGINAL: Manybrews
the traction control will endeed engage the brakes on the spinning wheels, forcing the driving power to the other wheels.
ORIGINAL: morten
Hi,
Cheers,
-Morten
Hi,
Cheers,
-Morten
I've had a test-spin, and apart from some engine noise, cheesy door-plastic on the inside and rather awkward-looking instrumentation, this is a solid piece of car! And, it'll get us to our chalet even on tough, icy mountain roads!
Again, thank you!
Cheers,
-Morten
#48
no, only the front wheel that is on the icy surface will spin, there is no limited slip for the front. The rear is its own transfercase, and limited slip combined... so, you would still have rear traction, on both wheels...
iF that helps
iF that helps
#49
ORIGINAL: soundcolor
iF that helps
iF that helps
#50
Yeah, thats basically what I was trying to say without saying just that. It hard for alot of people to understand there is no limited slip, but you get a limited slip effect... Oh well.
