Outlander 2005 won't start
Old May 7, 2015 | 08:04 PM
parspg's Avatar
Default Outlander 2005 won't start
Hi all,
I have a outlander 2005, from yesterday i heard clicking noise from the engine, also i had found out i have low Engine oil. today i have bout some oil and tried to add the oil while engine was running. after i had turned off the engine and tried to start, engine does not start.
clicking noise start when i turn the key for ignitions, my question is :
Does the noise is from water pump ?
why engine wont start?
God bless you all.
Old May 24, 2015 | 08:04 PM
BrianB's Avatar
Sounds like the starter or maybe just the starter solenoid.
Brian
Old May 24, 2015 | 09:13 PM
gggplaya's Avatar
My solenoid would click click click when my battery terminal was corroded. I would check that first, because that's quite obvious and free to fix.
Second, how do you know the engine oil was low???? Was the oil light on??? Or just wasn't showing on the dipstick??? Most dipsticks run out when you're a quart low, which means you could have over 3 quarts in there. The oil light in most cars only kicks on where there is no pressure in the oil pump, meaning you're truly out of oil.
How much oil did you have to add to get it to full? This is important to know.
mysticrythms
Mar 19, 2014 08:17 PM
Jboat
Feb 5, 2014 07:21 PM
guangui
Oct 10, 2013 07:23 PM
jaxoutlander
Mar 22, 2012 02:46 AM
TraciLou
Nov 8, 2011 03:20 PM
