Outlander Code P0868 Transmission fluid pressure (TFP) sensor - low
Hi all, getting the code P0868 on a 2011 CVT Outlander. Experiencing shudder on acceleration and eventually limp mode. I know this might be a transmission replace scenario, but anything I can do to prolong it or fix temporarily? If I clear the code drives as normal but comes back after short drive. Car is not low on fluid.
Transmission cooler was replaced due to mixing with coolant, and replaced transmission fluid (just drain and fill, not flush) a few months ago. Car drove fine after that, but this appeared today. Would dropping the pan and completing replacing the fluid and filter help? Thanks in advance Code: P0868 [0x0868] Transmission fluid pressure (TFP) sensor - low Transmission Fluid Pressure Low |
There was a wiring issue that affected these vehicles, but seeing as you have had contamination then it is not going to be the cause of this. There is no filter under the pan, The filter is behind the oil cooler. There is strainer in the pan to catch large fragments.
Easy to say now, but you should have sold it after the cooler went. |
Originally Posted by DibbyDibbyDJ
(Post 338295)
