Outlander cranking but not starting
Old Aug 29, 2021 | 04:32 AM
Martin sibz's Avatar
Default Outlander cranking but not starting
Hello,
my outlander is cranking and not starting, after diagnosing it, I came up with 2 error codes, P0 225 and P0120, what could be the solution to these errors? Do I change the throttle body?
Old Sep 1, 2021 | 07:58 AM
Sean Duffy's Avatar
One may be causing the other. I DID replace a TPS on a ford way back which was easy and cheap. This may be the cause the other issue. If you have u pull it yard nearby grab some parts. Never dealt with po225 but some help here.
https://www.yourmechanic.com/article...by-jay-safford
https://www.aliexpress.com/item/32764481664.html?spm=a2g0o.search0304.0.0.7c7a7af4 SNhFJl&algo_pvid=4e5d5897-9fc4-4d16-bdb0-3fb5a96743b6&algo_exp_id=4e5d5897-9fc4-4d16-bdb0-3fb5a96743b6-0 Throttle Position Sensor TPS For Mitsubishi Outlander $25
P0120
https://www.autoblog.com/2016/03/15/...t-malfunction/
https://www.aliexpress.com/item/4001150714133.html Accelerator Pedal Position Sensor MR578861 For Mi-tsubishi Outlander $25
Forgot to mention, clear the codes to see if it starts and THEN stalls.
lazzz
May 30, 2020 11:07 AM
09outlander
Dec 1, 2013 02:45 PM
rcpax
Mar 28, 2007 10:13 AM
biscuit
Feb 24, 2007 05:13 AM
fantomforce
Oct 23, 2004 03:39 PM
