Outlander Drinking Engine Coolant
Hi,
I have a 2007 (57 plate) 2.0L Outlander Elegance which seems to drink a lot of antifreeze/engine coolant. In a typical month, I'm probably adding about 500ml to the reservoir, as the reservoir will go from the maximum mark to well below the minimum mark after 1-2 weeks of reasonable use (200-300 miles per week). I have had the issue checked out at a couple of local garages, where they ran the engine for periods of time, but they couldn't find any leaks or moisture anywhere. When I first got the car (4-5 years ago), I recall reading on the forums that the Outlander has always been a little thirsty for engine coolant, but the amount I'm having to add seems excessive. Any comments or suggestions would be appreciated. Thanks |
Which type of Coolant are you adding?
I'm just topping up with a generic supermarket bought antifreeze coolant. I'm not sure which brand.
Originally Posted by granitehibby
(Post 315711)
Re-reading your first post...are you checking levels always with the engine hot/warm? Just thinking if you ate adding with the engine cold, the fluid may be expanding and exiting out an overfill tube.... just a thought.
Do what CCERNST said first and check the coolant to make sure it's not discolored, like it's mixed with oil.
Otherwise, i'm not familiar with european diesels, i know they're more relaxed regulations than american diesels. But a common place to leak coolant on diesels in the U.S. is at the COOLED EGR system, the valve and heat transfer area. You could leak coolant there and sometimes not see it and it wouldn't discolor the coolant either. I'm not sure what the emissions regulation in europe were in 2007, so you may or may not have a cooled EGR. |
One more thought. On the US 3.0 engine with a traditional automatic transmission, there is a coolant loop that goes to the transmission... I think to warm up the tranny faster via the engine. If yours does something similar, check transmission fluid as well for contamination.
Originally Posted by gggplaya
(Post 315738)
