Programming Door's lock
#41
JSRD,
Thanks for the info on this.
Can you clarify a few things. (I want to make sure I got the translation right. Its been a LONG time since Spanish class)
From your pictures, it looks like you found all the wires you need in the drivers kick panel.
I need to connect 30 to a white wire/black strip. This is the wire that will meter when I lock the car.
85 goes to White dotted wire, on a lower harness, and should meter when in reverse.
86 and 87 go to ground.
All this sound right?
#48
No me atrevería a decir que son los mismos colores, pero dado que se trata de coches de la misma marca, es probable que exista coincidencia; de cualquier forma, y basado en el relevador descrito en el post #41, necesitas conectar al terminal
#85 el cable que lleva la señal de la luz de reversa,
# 30 el cable de la señal de cierre de los seguros
# 86 y 87 a masa o tierra
Espero sea de ayuda la info.
#49
Encontre esta informacion:
Car Reverse Lights Wire (+): Red/Blue
Car Reverse Lights Wire Location: At Harness in Driver Side Kick Panel
Power Door Lock Negative Wire (-): Purple
Power Door Lock Negative Wire Location: At ETACS (ECU, Pin 33).
The ETACS (electronic timing/alarm control system) ecu
(electronic control unit) is attached to the back of fusebox.
Si estan bien las polaridades?
gracias
gracias
