Programming Door's lock
Old Jul 15, 2009 | 09:30 AM
  #41
jsrd's Avatar
Originally Posted by rip14
JSRD,
Thanks for the info on this.
Can you clarify a few things. (I want to make sure I got the translation right. Its been a LONG time since Spanish class)
From your pictures, it looks like you found all the wires you need in the drivers kick panel.
I need to connect 30 to a white wire/black strip. This is the wire that will meter when I lock the car.
85 goes to White dotted wire, on a lower harness, and should meter when in reverse.
86 and 87 go to ground.
All this sound right?
It's 0k rip14. I attach some pics in english
Old Jul 15, 2009 | 10:55 AM
  #42
rip14's Avatar
JSRD, you rock!!!
Old Jul 15, 2009 | 12:32 PM
  #43
rip14's Avatar
Thanks jsrd.
You pictures were a great help. It took about 10 minutes to wire, and saved me however much $$$ the dealership would have charged.
FYI for anyone else out there, the 09 is EXACTLY the same.
Old Jul 15, 2009 | 04:02 PM
  #44
jsrd's Avatar
You're welcome and congratulations
Old Mar 18, 2010 | 09:21 PM
  #45
jorgefv's Avatar
Hola jsrd
Crees que sirva para una Endeavor 2005?
Old Mar 18, 2010 | 09:56 PM
  #46
jsrd's Avatar
Originally Posted by jorgefv
Hola jsrd
Definitivamente, el truco estaría en encontrar las mismas señales para alimentar al relevador. . .
Old Mar 19, 2010 | 01:52 AM
  #47
jorgefv's Avatar
Seran los mismos colores de los cables?
Que señales exactamente debo de buscar?
Gracias
Old Mar 19, 2010 | 03:09 AM
  #48
jsrd's Avatar
No me atrevería a decir que son los mismos colores, pero dado que se trata de coches de la misma marca, es probable que exista coincidencia; de cualquier forma, y basado en el relevador descrito en el post #41, necesitas conectar al terminal
#85 el cable que lleva la señal de la luz de reversa,
# 30 el cable de la señal de cierre de los seguros
# 86 y 87 a masa o tierra
Espero sea de ayuda la info.
Old Mar 19, 2010 | 07:35 PM
  #49
jorgefv's Avatar
Encontre esta informacion:
Car Reverse Lights Wire (+): Red/Blue
Car Reverse Lights Wire Location: At Harness in Driver Side Kick Panel
Power Door Lock Negative Wire (-): Purple
Power Door Lock Negative Wire Location: At ETACS (ECU, Pin 33).
The ETACS (electronic timing/alarm control system) ecu
(electronic control unit) is attached to the back of fusebox.
Si estan bien las polaridades?
gracias
Old Mar 20, 2010 | 11:06 PM
  #50
jsrd's Avatar
Son correctas ; y ya que las tienes localizadas, sería muy simple la conexión a los terminales del relevador
Buena Suerte !
