Radio Fuse keeps burning out
Old Nov 19, 2007 | 12:09 PM
susie22's Avatar
Default Radio Fuse keeps burning out
I am lost and I need some help. My 2003 outlander was in an accident about two months ago. The other day, the car would not start and when I finally got it to start, the fuse on the radio burnt out. Everytime I replace the fuse with another one, it keeps burining out. Not only that, it makes the odometer (where it keeps track of the miles I am going), go back to zero and it resets the clock. I have changed the fuse several times and I do not know what to do now. Can someone please tell me what to do???
Old Nov 19, 2007 | 02:46 PM
oldpapa1949's Avatar
Default RE: Radio Fuse keeps burning out
Boy, sounds like a bunch of bad fuses.. When I go to Radio Shack I buy like 3 boxes.. 15 Fuses total.. But by the last Box I decide to find what is the real problem
I have to guess you have the main wire for power to the radio with insulation worn and rubbing against the frame or now pinched.
When it shorts, it resets other items that have the same connections.
Also look in areas where you might of poked into..
Maybe the repair shop dressed the wire wrong.. So check the harnesses around the radio.
Connect a 12 volt light in place of the fuse.. A short will make it light bright.. Pull the connector out of the radio and see if it dims..
If the connection is only for radio, it should go out..
Old
Old Nov 19, 2007 | 09:16 PM
dsm1990gsx's Avatar
Where was the car hit? I would check the wiring in that area, but yeah you have a dead short so what old papa said is a good idea.
pomerjon
Jan 19, 2010 01:49 AM
The Bassist.
Aug 31, 2009 10:08 PM
BlackGalant
Apr 24, 2009 07:40 PM
Cydric
Jan 14, 2009 06:41 PM
StRyKheR
Mar 16, 2006 03:34 PM
