Recall
Old Jan 18, 2008 | 10:18 PM
puddy's Avatar
Default Recall
Anybody else get a recall letter from the dealer this week?
I got one to check/fix the internal leakage of the tandem pump outstanding service campaign c0021310 the letter states its not a recall but tells you to get it fixed asap
is this part a diesel fuel pump?
Puddy
ps my car a 2008 diesel (vw)
Old Jan 19, 2008 | 06:19 AM
ronwill's Avatar
Default RE: Recall
I've not heard anything yet, mine also has the VW engine so i'd be interested to know what it is all about. Mine had it's first 12500 mile service between Christmas and New year so it may have had something done to it then but nothing was mentioned.
Keep us posted please as to what it all about.
Cheers
Old Jan 20, 2008 | 07:46 PM
tdford's Avatar
Default RE: Recall
I believe this is for the diesel models... '07 gas here, no letter.
Old Jan 20, 2008 | 08:20 PM
puddy's Avatar
Default RE: Recall
ORIGINAL: tdford
Yes my post said if this was part of the diesel pump
so its diesel engines
so its for diesel models
Sort of givesthe gameaway doesnt it?
DIESEL
My dealer has not been told yet about the recall
puddy
ps mines a diesel engine 2008 model
Old Jan 21, 2008 | 10:21 PM
tdford's Avatar
Default RE: Recall
ORIGINAL: puddy
ORIGINAL: tdford
DIESEL
puddy
You asked a question about if anyone recieved a recall letter.... I answered. You asked if the "tandem pump" was part of the DIESEL fuel pump...... I answered
Since yes I know you have a diesel, and you recieved a letter on a recall for a tandem pump, which is on a diesel engine, then ya, I believe this recall if for the diesel models.
...easy pudd, not my fault your dealer doesnt know about your recall yet.
Old Apr 10, 2008 | 10:31 AM
ronwill's Avatar
Default RE: Recall C0021310 Tandem pump
Just had my recall letter today re this ?? fault??
Was any work required on yours Puddy? (or anyone elses' for that matter! )
Mines going in next Monday for a check !
Ron
Old Apr 16, 2008 | 08:11 AM
Rubblepie's Avatar
My UK 07 plate diesel has been in to the dealer and had the tandem fuel pump replaced, the ECU updated due to cold weather stallingissues and the front wheel bearings replaced, twice,due to "clunk" noise on recalls in the last couple of months.
Since the wheel bearings have been replaced,twice due to still having clunk noise after first set replaced, my Outie veers to the left which increases with speed. The dealer appears not to know why. Can anyone help with this?
Old Apr 16, 2008 | 08:25 AM
ronwill's Avatar
Just had the tandem fuel pump replaced on mine this am. All seems ok but would not have known there was anything wrong anyway !!
What milegae has yours done Rubblepie?
Mine has done 13.5k now but no sign of any wheel bearing knock
Old Apr 16, 2008 | 08:31 AM
ronwill's Avatar
With regard to car pulling to left possible causes could be....... incorrect tyre pressure.....;front brake binding ( jack wheel up and see if it spins freely)...; worn suspension joint or front wheels out of alignment after being removed for replacement of bearings..
Could be one of any of the above or even some thing else ! Just a case of trying various things and eliminating them I'm afraid !!
Ron
Old Apr 16, 2008 | 09:15 AM
lozcart's Avatar
If your tyres are directional then check they have fitted your wheels back onto the correct side of the vehicle.
