Recall for back windows problem.
Old Oct 31, 2008 | 10:58 AM
jsrd's Avatar
Default RE: Recall for back windows problem.
ORIGINAL: ronwill
Not heard of this problem with UK / European models, has anyone else??
In Spain have this problem, and my dealer commented to me that it is at world-wide failure this situation, but did not say to me what models of units are the affected. . .
Old Oct 31, 2008 | 08:26 PM
bluebastion's Avatar
I have a 2008 that I bought less than 4 months ago. It still affects the 2008 models, and would not be surprised if it was affecting the 09's too. I was fortunate enough to go to a dealer who had already seen this problem on another Outlander and knew exactly which part to order and what needed to be done.
Old Nov 1, 2008 | 01:46 AM
rcpax's Avatar
How would you exactly describe this problem? I noticed on my 07 that the rear windows won't completely go down, only 2/3 of the way, which is weird. I wonder if this is normal or that issue you guys are referring to.
Old Nov 1, 2008 | 02:12 AM
jsrd's Avatar
The back windows don´t down completely, this is normal; the problem appears when the windows raising, doing it in an oscillating movement, when they must raise of uniform way.
Old Nov 1, 2008 | 08:36 AM
armymen's Avatar
somebody know how to be inform right from mistubishi for all the Recal the car have,
i already reveice a letter from theme, for the cable under the sear ( i have a 2008), but now i move, so is there a online thing that i can registrer to have all the recal ?
Old Nov 1, 2008 | 09:39 AM
BrodyGuy's Avatar
there is a page in the user manual, and also one in the maintenance booklet. should be on the front page. it tells you how to contact corporate incase you move so they can continue to inform you of vehicle safety updates.
Old Nov 1, 2008 | 05:45 PM
jsrd's Avatar
ORIGINAL: cybergoogle
does this recall also affect US model?
It is probable this problem appears in the models U.S., but the recal is specific for the units sold in Mexico, I think that in Mitsubishi will do his own recall in each country to correct this situation. . .
Old Jan 4, 2009 | 07:40 PM
LotusRacerX's Avatar
This exact thing just happened to me...window was teetering back and forth, and ended up cutting the black paint of the window frame.
One thing about this problem...we had noticed since it was new that the bottom window frame plastic piece was bowed up in the middle. May be a warning sign of this problem.
Old Jan 10, 2009 | 08:15 PM
BrodyGuy's Avatar
has it ever dropped out of the door?
Old Jan 10, 2009 | 08:34 PM
It becomes quite stuck...rather than falling out, I would expect the glass to shatter if you continued to press the "UP" button.
