Regarding rear inside tyre wear.
Old Sep 7, 2016 | 12:35 AM
private50's Avatar
Default Regarding rear inside tyre wear.
Hi, I have an es zj 2014 4wd Outlander. I am having trouble with both rear tyres with inside wear. I tow a 12ft caravan and I am inside the maximum requirements regards to ATM(1600g) & ball weight (160kg)allowances. I had a 4 wheel alignment but all adjustment fails to align properly. I have been told I need rear camber kits fitted but Mitsubishi do not make or supply them and I have tried suspension shops and they can't access them either. Does anyone out there know if and where they can possibly be obtained. Thanks, Rob.ý
Old Sep 7, 2016 | 01:40 AM
quadcam's Avatar
Camber does not cause inside wear but toe out does. The camber might accentuate it though. Maybe load the rear of the car so it sits at the same ride height as when the van is connected and then have the rear toe checked.
Old Sep 7, 2016 | 05:10 AM
private50's Avatar
Thanks Quadcam, Mitsubishi service says one thing and their spare parts says another. Cheers Rob
batman47
Jan 10, 2014 10:53 PM
roys
Mar 29, 2012 09:53 AM
cat_quek
Oct 15, 2007 11:07 PM
stan63dt
Aug 31, 2007 09:14 PM
