Remote starter
Old Feb 16, 2016 | 03:42 AM
stanza75's Avatar
Default Remote starter
Got 2008 xls Outlander with FAST key and was thinking about installing a remote starter. So far, I'm not sure if i should install the aftermarket or OEM. Any advice on pro and cons of either one will be appreciated.
Old Feb 16, 2016 | 04:58 PM
11SE2HEAR's Avatar
Do you want to carry around two keyfobs or one? How much distance are you going to be from the car to start it? Did you need a two-way system that lets you know the vehicle has started or will it be within your line of sight?
Old Feb 16, 2016 | 05:48 PM
gggplaya's Avatar
I'm actually looking at installing a Cellular one with a smartphone app, but i'll do that in the summer getting ready for next winter.
Old Feb 16, 2016 | 08:50 PM
SERPENTOR's Avatar
Old Feb 16, 2016 | 08:53 PM
gggplaya's Avatar
Yea, because i can sit inside my office and warm my car up 15 minutes before i leave. How awesome is that!!
Old Feb 17, 2016 | 01:12 AM
stanza75's Avatar
I called a mitsu dealer and they quoted me $550 for the installation of OEM remote start. The biggest problem i have with their remote starter is its short range. They said its UP TO 300 feet. That seems too short a distance for me. I dont mind to carry two keyfobs if thats what going take to have aftermarket remote start with a long range.
Old Feb 17, 2016 | 01:53 PM
gggplaya's Avatar
I would hesitate with "LONG RANGE" They probably have more range from having a larger antenna, which is usually taped to the top of the windshield. But keyfobs are generally low power devices with wattage limitations set by the FCC. I know some claim 2000-3000ft, but that's really unrealistic to believe a fob can do a full half mile range, especially with such low wattage and having to go through walls, trees , bodies of water or other obstacles.
If perhaps you live on a campus, or apartment complex, or park curbside down the street, then i'm sure you want the most range possible. I think a cellular system will be more reliable for what you need. If you get a system like the compustar drone system, you can have the best of both worlds, a normal FOB, or use your smartphone to start the car or unlock doors. The subscription is $50 per year, or $120 for 3 years. If you don't pay the plan, you can still use you backup Fob to start the car.
No5
Oct 30, 2007 08:20 PM
nawgee
Jan 27, 2007 04:32 AM
MrJayDeeOne
Apr 7, 2006 11:13 PM
pointman
Nov 7, 2005 07:03 PM
Smejk
Feb 11, 2005 07:34 PM
