Run a V6 on 4 Cylinders
Old Apr 17, 2008 | 06:26 PM
Number6's Avatar
Default Run a V6 on 4 Cylinders
I've heard that there are some V8's out there made to run on 4 cylinders when the demand on the engine is not that high. Has anyone ever heard of a mod that could do this for any V6? It seems like it would just be a software change.
Old Apr 17, 2008 | 06:52 PM
dsm1990gsx's Avatar
Default RE: Run a V6 on 4 Cylinders
There isn't anything like that for v-6's b/c most already get pretty good mpg. AlsoI think the engine balance would be thrown way off in a v-6 and wouldn't run very well. I think gm had it in the early 90's and always had problems.
Old Apr 17, 2008 | 09:42 PM
rzozaya1969's Avatar
Ford also had that for the Excursion (?) the large SUV. It had 10 cylinders, but it could turn 2 off.
tcp's Avatar
tcp
The current honda odyssey touring edition has cylinder deactivation that lets it run on 3 cylinders instead of 6. It requires an active noise cancelling system as it creates resonances. In real world conditions, it doesn't do much for fueleconomy either.
http://www.canadiandriver.com/articles/jk/041014.htm
Old Apr 18, 2008 | 02:52 AM
HandyPal's Avatar
Speaking of the software change.... would be neat if no other things had been involved.
You should stop playing too much with computers, hehe...
If you're into saving gas - get a green car or simply don't push too hard what you have.
Another tip is to mix some alcohol into the gas, some pumps already offer this kind of stuff, it burns cleaner too.
Old Apr 18, 2008 | 06:30 AM
nontoxicart's Avatar
Or JUST trade-in your car for a bicycle lol
Old Apr 18, 2008 | 06:41 AM
antlip's Avatar
Thats v8 technology. It will run on 4cyls to save fuel but be able to have power when needed. Kind of like an over drive. Oh and its only giving the trucks like 20mpg.
Old Apr 18, 2008 | 08:01 AM
chenarm's Avatar
It requires more than just shutting off fuel and sparkto the cylinders, If that's all you didyour stillpumping air in and out of the disabled cyls. So half the cyls work and the other half are essentially an air compressor. You also need a way of disabling the valves for the cylinders you want to shut off. You're still compressing and uncompressing the air that's in the cylinder but it's a lot less work than a normal cycle, since the cylinder that is compressing is helped by the reciprocating cylinder that is expanding.
Old Apr 18, 2008 | 01:09 PM
tdford's Avatar
ORIGINAL: chenarm
Ya, this in NOT a mod that you can do. Pretty much has to come from the manufacturer. Because as you can see... its not simple.
Old Apr 21, 2008 | 06:42 PM
Number6's Avatar
Oh right.I forgot about dealing with the in-bound air.
3 cylinders on the Odessey? That's sounds crazy! Wouldn't think you could keep a minivan moving forward on that many.
I think I'll just get me a cheap-o mid-90's civic or tercel for commuting. Those get like 40mpg and go for $1500-$2000. I'd get an 89 CRX-HF (50+ mpg), but people that have ones that run aren't selling them these days.
