Scanner MUT-3
Hello,
I am interested in buying a scanne for my outlander. What do you think about Mut-3? I found some with very reasonable prices. Does anyone of you have this equipment? Any specific model/version for outlander? Rgds, Marcelo |
I do have it.
Originally Posted by Vadimus
(Post 303288)
I do have it.
Hello Vadimus, Whatīs your opinion? Is it good? Itīs works well? Itīs possible "clean" the service required message? There is some specific version? Will be my first scanner. Rgds, Marcelo |
Are you sure you want to spend at least $600 for just service required message? Is it an oil change reminder or something like TPMS or ABS service required?
First could be managed by just Info button, second won't be solved by MUT, you'll need to repair actual problem indicated by this message. |
(Post 303306)
First could be managed by just Info button, second won't be solved by MUT, you'll need to repair actual problem indicated by this message. Hi, It will not be just for this purpose, but it would be good if itīs possible to clean the message "period inspection". Is it possible? Regards, Marcelo |
Yes, just read the owner's manual. Info button does the trick.
(Post 303318)
Info button does the trick....Is it possigle clean this message without use the scanner? |
Originally Posted by Michelin
(Post 303319)
Good morning, I found here in the forum, the topic about this issue. I did the steps and my periodic inspection was extended. I donīt know if I am able to repeat what I did again...... Rgds, Marcelo |
