Scanner MUT-3
Old Jul 3, 2014 | 08:56 AM
Michelin's Avatar
Smile Scanner MUT-3
Hello,
I am interested in buying a scanne for my outlander. What do you think about Mut-3? I found some with very reasonable prices. Does anyone of you have this equipment? Any specific model/version for outlander?
Rgds,
Marcelo
Old Jul 3, 2014 | 11:51 AM
Vadimus's Avatar
I do have it.
Old Jul 3, 2014 | 04:14 PM
Michelin's Avatar
Originally Posted by Vadimus
I do have it.
Hello Vadimus,
Whatīs your opinion? Is it good? Itīs works well? Itīs possible "clean" the service required message?
There is some specific version?
Will be my first scanner.
Rgds,
Marcelo
Old Jul 3, 2014 | 09:34 PM
Vadimus's Avatar
Are you sure you want to spend at least $600 for just service required message? Is it an oil change reminder or something like TPMS or ABS service required?
First could be managed by just Info button, second won't be solved by MUT, you'll need to repair actual problem indicated by this message.
Old Jul 4, 2014 | 06:51 PM
Michelin's Avatar
Smile
Hi,
It will not be just for this purpose, but it would be good if itīs possible to clean the message "period inspection". Is it possible?
Regards,
Marcelo
Old Jul 4, 2014 | 07:30 PM
Vadimus's Avatar
Yes, just read the owner's manual. Info button does the trick.
Old Jul 4, 2014 | 08:10 PM
Michelin's Avatar
Smile
Info button does the trick....Is it possigle clean this message without use the scanner?
Old Jul 5, 2014 | 07:45 AM
Michelin's Avatar
Smile
Good morning,
I found here in the forum, the topic about this issue. I did the steps and my periodic inspection was extended. I donīt know if I am able to repeat what I did again......
Rgds,
Marcelo
Vadimus
Jun 12, 2023 10:01 PM
RoGuE_StreaK
Mar 11, 2014 10:51 AM
jason0595
Aug 31, 2009 11:30 AM
