Seat removal to install sound barrier
Old Sep 19, 2022 | 09:07 PM
DLR's Avatar
DLR
Default Seat removal to install sound barrier
Hello,
I have a 2015 outlander sport with a ton of road noise. I’d like to remove the seats and carpet and install sound barrier in the floorboard. Does anyone know if I will screw up or disable any of the sensors by removing all the seats? I found one remark in the owners manual about a weight sensor for the front passenger seat stating to insure proper operation of the weight sensor if the seat is removed.
Any help would be appreciated.
Dave
Old Sep 20, 2022 | 04:40 PM
DibbyDibbyDJ's Avatar
as long as you unplug the connectors under the front seats with the battery disconnected there should be no concerns. If you do have the ignition on during disconnection then there is a risk of seat airbag deployment, or inducing a fault code in to the system.
]under the rear seat, which js clipped in using metal rings, which need a good firm pull upwards to unlatch, there may not be enough room for thick insulation, and bear in mind access to the fuel filter is under that seat also, so there is a risk of damaging the insulation, when it needs changing
Old Sep 20, 2022 | 05:54 PM
DLR's Avatar
DLR
Thank you sir!!!
Flatcreeker
Aug 7, 2016 09:51 AM
jmoss4949
May 22, 2014 10:03 AM
OutlanderGT
Oct 16, 2013 10:17 PM
theoh
Nov 9, 2009 05:43 PM
Tasman
Jan 7, 2009 11:24 PM
