"Service Engine Soon" Code: 1320 + 2 Rotted Coolant Lines
Old Nov 21, 2021 | 09:13 PM
SERPENTOR's Avatar
Default "Service Engine Soon" Code: 1320 + 2 Rotted Coolant Lines
Vehicle 2008 Mitsubishi Outlander XLS V6 4X4
137,000 Miles
Currently have a "Service Engine Soon" Light on dash and used Bluedriver to pull Code: 1320 "IG timing retard insufficient" (What exactly does that mean how can I fix it?)
+ 2 Rotted Coolant metal Lines
1st Rotted line is the Oil Cooling Line
2nd Rotted line is the Trans Oil Cooling Line
What can I do to fix these issues? How much do the replacement cooling lines cost? (Labor/Part Price breakdown) does anyone know the part numbers, are there aftermarket options for these two metal coolant lines or do you have to buy them Mitsubishi Directly?
I have a slow coolant leak, currently filling up the coolant tank every 1.5, 2 weeks looking to solve this issue, appreciate any help!
Old Nov 21, 2021 | 11:54 PM
DibbyDibbyDJ's Avatar
Sound like the knock sensor is either working overtime trying to correct the spark, or it has failed totally
Old Nov 22, 2021 | 05:06 AM
SERPENTOR's Avatar
Sorry not sure what that means, what is bad the spark plugs, knock sensor? What parts do I need to replace how much does something like this cost? Labor/Parts?
Old Nov 23, 2021 | 03:43 PM
Sean Duffy's Avatar
Default knock sensor
Best go to rockauto.com site or other supplier and look at the part posted, take a pic of the knock sensor then try locate it on the engine and replace yourself. I have replaced metal lines with rubber before. Be sure it says, "for trans line on the hose". They are high pressure hoses. Expensive ($5/ft) but less cutting screwing with rusted parts.
**** How do you eat an elephant ? One piece at a time. Do one part at a time or be overwhelmed.
Old Nov 28, 2021 | 06:35 AM
SERPENTOR's Avatar
Thumbs up
Is it normal for Knock sensors to fail? It has been there since 2008 so I see why it could have just reached the end of its lifespan. If I took this to a Mechanic how much would be fair for them to charge me?
Appreciate any help!
Old Nov 29, 2021 | 03:54 AM
eloMeTh's Avatar
Did some searching and looks like the code can be due to the following below. The Faulty Thermostat and ECT signal causes leads me to think that it could be related to the coolant leaks.
  • Faulty Thermostat
  • Faulty Engine Coolant Temperature (ECT) sensor signal
  • Faulty Engine Control Module (ECM)
https://www.engine-codes.com/p1320_mitsubishi.html
Old Dec 3, 2021 | 10:39 PM
SERPENTOR's Avatar
  • Faulty Thermostat
Thank you! Appreciate the findings.
These are the pictures of the rott does anyone know the part name or part number so I can special order it and replace it?
https://imgur.com/a/81b5z6U
Going to order from Rockauto.com if they don't carry it would order from https://www.mitsubishipartswarehouse.com/
How much should labor cost on a replacement like this?
Old Jan 25, 2022 | 04:18 PM
SERPENTOR's Avatar
Replaced Rotted/Rusted engine and trans coolant lines come to find out that the Oil Cooler Radiator - Mitsubishi 2920a024
2007-2009 Mitsubishi Outlander has a hairline crack. Do they make an aftermarket part other than OEM? Appreciate any help!
2008 Mitsubishi Outlander XLS 3.0 V6 4X4
Old Jan 27, 2022 | 02:43 PM
eloMeTh's Avatar
See some on ebay for about $100 with the 2920a024 part number, but not sure of the quality. OEM looks pricey so maybe worth a shot?
Old Jan 30, 2022 | 09:30 PM
SERPENTOR's Avatar
Thumbs up
I saw that one too looking for a Lifetime warranty or more than 3 months, appreciate the suggestion!
