Shutter on slow-down when cold
Old Oct 6, 2012 | 08:39 AM
milliesdad's Avatar
Default Shutter on slow-down when cold
20012 Outie V6, auto.
I'm guessing that it's the lock-up converter un-locking when comming to a stop when the engine is not fully warmed, Noticed it several times,not a constant thing.
anyone else experience this? Before I take it in and be told it's what I think it is?
Old Oct 8, 2012 | 07:12 PM
O-lander's Avatar
How rough is it? If it is sloshing your coffee out of your cup have a real problem. Otherwise I'm pretty sure that this is just a byproduct of the ECU running the idle at 900-1000RPM (about 300-400RPM faster than normal) to keep it from stalling. The transmission is expecting the lower RPMs as it downshifts so you get more of a thump and a bit of jerk on every downshift.
The next time it does this pull over and put the car in park or neutral and compare the tach to what it is after the car warms up.
Torque converters usually only lock at highway-type speeds.
Old Oct 9, 2012 | 06:20 PM
milliesdad's Avatar
Thanks.
On second thought, the converter will lock up at higher speeds.
I beleive you are right about the down-shifting thing.
Old Oct 9, 2012 | 08:48 PM
quadcam's Avatar
Mine doesn't do anything like you describe, it just comes down as expected.
niazqamar
Apr 27, 2022 08:22 AM
cu2cecil
Nov 30, 2010 05:49 PM
Eclipse440
Jan 16, 2008 07:49 PM
MitClipseGS99
May 7, 2004 10:54 PM
twistid_desirez
Mar 27, 2004 01:05 PM
