Solenoid for the evap system?
Old Aug 25, 2013 | 03:23 PM
BrindleBeauty's Avatar
Default Solenoid for the evap system?
Hey guys,
I have an 2003 outlander with a small evap leak (p0456 I think). The mechanic thinks it's the solenoid. No leaks were found with a smoke test. Does anyone know a ballpark of what I'm looking at cost wise? Also looking for both headlight assemblies any good places to find em? Thanks!
Old Aug 25, 2013 | 05:50 PM
That part isn't typically expensive, about $50-$75, and they aren't difficult to replace either. Either that or your gas cap, which you can eliminate usually by applying a thin coating of vaseline around the rubber o-ring of the gas cap. Then clear the code using a code reader or unhook the negative battery terminal for 10 seconds. That should do the trick.
I advise having a mechanically inclined friend do it, rather than paying some shop monkey to do it.
Grudge302gt@att.net
May 21, 2016 09:23 PM
Pr0x1mo
Aug 3, 2014 12:24 PM
MzKia80
Jul 18, 2011 10:38 AM
Gonzo231
Jun 25, 2011 02:29 PM
laroser
Jun 3, 2010 03:24 PM
