Speaker size?
Old Sep 22, 2005 | 01:50 AM
Jewelz's Avatar
Default RE: Speaker size?
I bought a set of Pioneers from Best Buy.
Old Sep 22, 2005 | 04:49 AM
Punisher's Avatar
ohh. best buy sometimes doesnt know what they talking about. they couldnt get al of my head unit in so I had to install it myself [:@]
anyway, this set fit in, or is this the 6.75 you looking at?
Old Sep 22, 2005 | 12:26 PM
JMC's Avatar
JMC
They look nice....it's still weird about the size.
Old Oct 19, 2005 | 04:30 PM
trek's Avatar
Hey Guys, I like everybody else bought 6.5" speakers. But they don't fit. Like Jewelz said before. I bought 2 pairs of Alpine Type S speakers. But they were too small like I said. So I had the smart idea of using the speaker mounts from the stock speakers. And it worked great. What I did was:
1. First remove the factory speaker.
2. Dremel the cone off. Yes, Cut the CONE and Magnet OFF.
3. Your left with an O shaped mount with the factory holes.
4. Lay the new smaller 6.5" speaker face down on this newly made O mount.
5. Now the tricky part. Carefully drill four new Pilot holes for the new speaker. Wilth 1/16" drill bit.
6. Screw down the speaker to the O mount and Install the Door.
There you have it...
The first speaker was the hardest because I didn't know what to expect. It roughly took an hour to finish. But the other three, I did in half that time. The Plastic is fairly robust, but I would still recommend taking your time not to crack the plastic. But if you do, don't worry just use some epoxy glue.
I know, I know post some pictures.... I will very shortly.
Old Oct 20, 2005 | 01:30 AM
Punisher's Avatar
actually, I was thinking of this solution, but nobody spoke further of a problem.
very good trek!
Old Oct 20, 2005 | 12:07 PM
JMC's Avatar
JMC
That sounds perfect...please get some pics when you can!
Old Apr 11, 2018 | 10:41 PM
Brentskii's Avatar
I know this is 13 years later but is this the same size for the 2010 outtie with the rockford fosgate speakers?
Old Oct 20, 2019 | 04:56 PM
THEYNINE's Avatar
I have a 2006 outlander. I ordered some JVC CSJ620 which claim to be 6.5". ( They were cheap) I discovered they were too small for the hole and had to pick up some adapters so they would fit. Seems there is a difference in how manufacturers are defining size.
eclipseGS98
Aug 12, 2008 02:40 AM
SGCroxton
May 4, 2007 09:07 PM
andysila
Aug 19, 2005 10:28 AM
Laxstar785
Mar 23, 2005 09:41 PM
jayno20
Sep 16, 2004 03:59 AM
