SRS Light stays on 05 outlander HELP!
I was messing around checking fuses and now my srs light won' go off, Please help, wife is driving me nutzzzz LOL:confused:
What exactly were you doing?
You may have disabled a critical safety system.... If you can't find the cause, take it to the dealer to get it scanned, they will tell you which component set the code. |
Might be a little late now and you may have it fixed but...
Had the same sort of problem. After a but of messing around I turned out to be a broken track in the clock spring. They wanted a few £££ to replace. Its a common fault as the wire rubs. Bad design. On he end I went to beakers yard and had the full unit out of a mitx gallant. The spring was different as was the connectors but the soldering iron helped to replace. The housing was the same so £5 and a bit of time. You need to take the wheel off and airbag out. All the best Phil |
