SRS Light stays on 05 outlander HELP!
Old Jun 27, 2014 | 09:17 AM
geezcow's Avatar
Unhappy SRS Light stays on 05 outlander HELP!
I was messing around checking fuses and now my srs light won' go off, Please help, wife is driving me nutzzzz LOL
Old Jun 30, 2014 | 11:19 AM
Guyfromhe's Avatar
What exactly were you doing?
You may have disabled a critical safety system....
If you can't find the cause, take it to the dealer to get it scanned, they will tell you which component set the code.
Old Jul 5, 2014 | 04:03 AM
activeviii's Avatar
Might be a little late now and you may have it fixed but...
Had the same sort of problem. After a but of messing around I turned out to be a broken track in the clock spring. They wanted a few £££ to replace.
Its a common fault as the wire rubs. Bad design.
On he end I went to beakers yard and had the full unit out of a mitx gallant. The spring was different as was the connectors but the soldering iron helped to replace. The housing was the same so £5 and a bit of time.
You need to take the wheel off and airbag out.
All the best
Phil
pratik91
Feb 9, 2011 12:04 PM
schurmana
Dec 1, 2009 05:41 PM
shum_87
Aug 29, 2009 05:05 AM
debbiesz
Aug 4, 2009 02:20 PM
03outlander
Sep 16, 2008 01:15 AM
