srs light stays on
Old Jan 7, 2011 | 08:56 PM
pratik91's Avatar
Default srs light stays on
hi guys .
wanted to know y would my srs lights stay on all the time
Old Jan 13, 2011 | 12:08 AM
SCOTTSS's Avatar
Sounds like a bad clock spring. You have to remove the steering wheel in order to replace it. When it fails the Safety Restraint System light comes on. I had the same problem on a 1999 galant. The horn and cruise control started working after I replaced the clock spring too.
Old Jan 18, 2011 | 11:03 PM
jgbrules's Avatar
well that is certainly an idea. but the most sensible thing to do is to get it scanned and see what the actual code is. then you dont just start throwing parts at it. srs parts are expensive. just sayin!!
Old Jan 19, 2011 | 05:35 AM
SCOTTSS's Avatar
Well said. Pulling the codes is the most logical way to go. I was lucky the clock spring fixed my SRS light. In my case all signs pointed to the clock spring since both the horn and cruise control receive power thru the clock spring and neither were working. I don't have access to a scanner so I had to do it the old fashion way with flow charts and searching forums like this one to pinpoint the fix. Ya know
Old Feb 9, 2011 | 12:04 PM
civicduty13's Avatar
Originally Posted by pratik91
hi guys .
What year galant? Where is the light located at on the dash?
geezcow
Jul 5, 2014 04:03 AM
schurmana
Dec 1, 2009 05:41 PM
debbiesz
Aug 4, 2009 02:20 PM
pgb205
Jun 4, 2009 10:40 PM
03outlander
Sep 16, 2008 01:15 AM
