Sub and car rattle ? with the 650 W Rockford forsgat ?
My Rockford sub's bass is quite inadequate to cause any rattles, even set up to +6. I was wondering if the amp could be changed out for something stronger?
Or is there some common problem I am not aware of?
if you switch out the amp it will not be covered under the warranty. and if you want a more powerful amp, you need to upgrade your sub to make sure that you don't overpower the stock sub. its a lot of hassle with little gain.
