sunglass holder
I have added it by cutting the headliner without removing it. If you remove the dome light assembly and stick your fingers through the hole towards the back of the car, on the upper surface of the headliner will be groves easily touchable, marking the outlines for cutting. I determined the corners, punched nails from the space between the roof and the headliner and towards the cabin and then used the serrated knife to cut it from inside the cabin. Use shorter knife to avoid hitting the metal roof while cutting. Not sure if I missed my line or the markings were wrong, but mu opening was some 2-3mm larger, not a big deal, however it would be better if the fit was snugger. Works great... Mine is Outlander 2008
2008, 2013, 403032001, compartment, holder, lancer, misubishi, mitsubishi, montero, number, outlander, part, pocket, sunglass, sunglasses
